Who fancy a challenge?
Recreate this in Onshape, prove that Onshape is better than Solidworks or Fusion.
And here is an dwg: https://cad.onshape.com/documents/4b5c7480fa796f96d9c9f542/w/47d8242ba97f69df693a4558/e/7f1d1fefce208d9facb937f4
https://cad.onshape.com/documents/39369c7fe89d343a835363dc/w/4c259cbc4e31028ea24d5754/e/b0228ac5cf7949b4a73c17a8
projektowanieproduktow.wordpress.com
Lets see who has it ready to go when we push
I have a feeling it won't be me solving this!
This is why we have servo driven mechanisms and not cams!
There is no single FS just Sheet Metal for "wrap". But That wasn't the point of the challenge.
I was working on this model for F360 forum (https://forums.autodesk.com/t5/fusion-360-design-validate/solid-model-from-wrapped-geometry/td-p/8969749) and this was a nice case to show how SM can help to bend if you know what K factor means actually.
I was hoping that sweep will do the slot... but even with rails and guide surfaces, it was not enough. Eventually, I've ended with loft approximating the right shape (which wasn't right at all, and I knew that just after posting on F360 forum and before posting here).
This approximation with loft is something I do quite often when I have complex "rule" driven surface.
I was sure that this model is such case and I was wondering what Onshape can offer (some FS)?
It turns out that I was too hooked on a sweep and didn't investigate enough the geometry itself.
When @konstantin_shiriazdanov posted his response, I immediately went to model and edited Cylinder sweep custom feature, and saw this:
I swear I could hear a CLICK in my head and a voice: thicken and fillet you DUMBASS.
So ok, this model couldn't challenge anyone... but still I do sometimes lacking more control over sweep/loft in certain cases.
When I find one I will try to poke the sleeping bear again.
I don't doubt it's well thought out, you've proved yourself many times here Konstantin.
Here is my take using the new "Wrap" feature. I still had to use Thicken to get the parallel side walls, so some of the fillets are a bit wonky and there's a small matter of non-manifold geometry at the bottom of the slot requiring a minor dimension tweak (within tolerance of course). 28 features - BOOM!
We like a good modeling challenge, so if you find any more please post!
https://cad.onshape.com/documents/6e98b5b5515c5c31ee98896f/w/cd7a7f83561fcde67b09c827/e/c73b1f5a5837953dcd0b1b0b
That's why I think that whole view is "faked" because it doesn't refer to any finite value for radius/diameter (of course maybe this value is close to some common imperial units value? Don't know that system at all).
