issue with sweeping curves
table38
Member Posts: 14 EDU
This is for a THT part making leads with sweep tool isn't working. Sketch 1 is guide path and Sketch 2 is profile.
https://cad.onshape.com/documents/31d7342ed8cf5edf50bfe297/w/86318314347464ebab042339/e/ea24f76335a4b695a2a30c29
At at the bend in the path you are asking the sweep geometry to go inside itself (“self-intersecting”) which is physically impossible.
The sweep feature was made as Add and using Union to merge the 2 parts will still leave a gap between part and leads.
https://cad.onshape.com/documents/33ac0357d7e57ad543b9cc02/w/cb782a56667e53da5edfef95/e/265c2c8714d42495ede5bffa
