Path with Loft and two cross sections
kai_h_borbe
Member Posts: 14 EDU
Hey Forum,
i need your help again. I like to design a level with two different cross sections. The problem are the planes for the guidlines. The plane "path" is align with line angle, so i can catch only three points of four, but i need four, to use the loft tool with guides. The lines have to point the edgepoints of the cross sections.
If i get in the sketch mode of sketch "Opening two", the plane and sketch of "level" disappears. If i move the sketch "opening two sketch" to the end, the align of the plane "path" changes.
How can i use the "use" tool to get all four points to one sketch ?
This is a screenshot:
Blue: Align of the plane "path"; Red: the Point i need to move.
Here is a link to the projekt: https://cad.onshape.com/documents/c2ef8a7ff3b7b0f7587b0219/w/1a24c9901eb39039cd822e14/e/f374a5f45d5a80316dd7539f
Best regards
Kai
