mirror sheet metal features
bryan_lagrange
Member, User Group Leader Posts: 792 ✭✭✭✭✭
in General
Is there a video or tutorial in mirroring sheet metal features?
I can mirror a body and combine or mirror a body and make a new part, but I can not mirror a feature. I can mirror a sketch and then use that sketch to make a feature.
Is the mirror command still limited in sheet metal?
Thank you
Thank you
Mirror and pattern in sheet metal are still some-what limited. You should be able to do face pattern, which would frequently be sufficient. e.g. https://cad.onshape.com/documents/9799413e3d838b1f58568345/w/8b90bf4bf00d27c3b2966c73/e/593b1341b1f64511ed0d0c6f
Twitter: @BryanLAGdesign
