different colors on one part object
stefan_stoll
Member Posts: 2 EDU
in General
Hi there
it is possible to assign different colors to the individual surfaces of a part object.
If so, please give me a short description.
Thanks in advance.
Stefan
Stefan
1
Remember, if there is a function you need but Onshape does not have it.
Check out the improvement request area on the right ----->
and cast your vote for all of the features you need.
Colored Faces is one of these IRs (Improvement Requests) so please add your vote here:
https://forum.onshape.com/discussion/1293/coloring-faces#latest
Yes, and then consider changing it to an "open" Composite Part so you can have it act like a single part in an assembly
https://cad.onshape.com/help/Content/composite_part.htm?Highlight=composite%20part
