To fix this, Release the drawing and export the Revision instead of the Workspace Version of the drawing - then the watermark is removed.
(I know that's not what you're after, but I think it's what we've got until Onshape makes some changes).
@guy_rogel have you made an Improvement Request?
I know what water mark is. I do not want to remove it. in many cases we use non released drawings for different purposes. it's good to have the water mark on them. i'ts just not "transparent enough" this is what I would like to improve. Just like it's transparent while reviewing on onshape
