Trouble with extruding
zach_lane579zach_lane579 Member Posts: 2
I am having an issue with extruding the S on this design.  I was able to extrude everything but the s and the big center of the circle.  Link below.  I am getting an error saying Extrude did regenerate properly, Check input.  It appears it is all closed
.https://cad.onshape.com/documents/c67c86c7d2d8d9e5ac3f2d40/w/627f01404534d8332f1648c3/e/3c9de18c7802dd488270acf2
  • bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    @zach_lane579
    looks like you fixed it?
    Another topic - do you want all the components to be seperate parts.  If not change the extrudes to 'add' instead of 'new'.  Or boolean them together...
    www.accuratepattern.com
  • albert_turneralbert_turner Member Posts: 2 EDU
    I'm getting the same error message and my sketch is shaded, what did you do to fix it?
    @albert_turner
    Welcome to Onshape and the forum.
    You likely have an open sketch and the shading you see is imprinting.  You can turn imprint off in the sketch dialog.
    if you share a public document we can better help
    see instructs here
