Create document in new tab.
tim_hess427
Member Posts: 648 ✭✭✭✭
I wish there was a way to open new documents in new tabs. There are certain stages in projects where I'm creating several new documents in short succession and its a pain to keep re-opening the "Documents" page. At a minimum, changing the default behavior would be an improvement. Whenever I'm working, I like to keep one tab open with the documents page at all times.
If you're debating whether this is important: Just imagine that Finder or Windows Explorer closed every time you created or opened a document. Wouldn't that be frustrating? Why should Onshape's behavior be different?
P.S. - I know that I can right-click on a document and open it in a new tab, which is why I'm specifically asking about creating new documents here.
