Which plane for 3D printed parts?
perry_ismangil
Member Posts: 8 ✭
Optionsowen_sparks Member, Developers Posts: 2,660 PROHowdy
Doesn't matter. The 3D Print Software (aka slicer) will allow you to position the part as you wish.
Chances are you'll want to move it anyway to allow for either maximizing strength, minimizing support, fitting other parts on the bed etc.
Usually the printer's Z axis will be up, so that'll match the view in OnS.
HWM-Water Ltd5
As for my experience it is usefull to orient simple parts on the top plane as that is how it will be placed originally in Cura, Slic3r and friends. Otherwise you need to manually orient it each time.
Ideally I would use an assembly as a printplater, see :https://forum.onshape.com/discussion/13115/design-flow-for-3d-printing
