Show mates only works for parts, not subassemblies
Mike_Warner
Member Posts: 1 ✭
The "Show Mates" command within an assembly only works for parts, not subassemblies. Right clicking on a subassembly within the assembly you are working does not allow the "Show Mates" command. This can be extremely frustrating if you are trying to see which mates constrain the parts within the subassembly in the context of the main assembly you are working. Please add this feature
https://forum.onshape.com/discussion/comment/59618#Comment_59618
https://forum.onshape.com/discussion/8799/select-mate-connectors-in-context-menu-assembly
