Is there a simpler way to model this circular wave geometry?
daniel_baileydaniel_bailey Member Posts: 7
I have modelled a wavy track designed to be a surface on which a cam rides, and is pushed up and down.
See the part in this document:
https://cad.onshape.com/documents/7123abbf4f9c97ed7b66a0cc/w/73e8d2b6da1ef1e5bdadd74a/e/62138605073e04d49c30108c
Currently, to create this part, I have to...
 - create a pair of curves that match the top of the waves on the inside and outside of the tube on which they sit
 - loft these curves down to circles on the base of the tube
 - split the resulting surfaces into pairs of surfaces and draw extra lines between them
 - fill the two areas surrounded by these curves that now define the top surfaces
 - then split, add lines and fill again for the bottom surface
I know the last set of [split, draw lines, fill] could be avoided as that's just a flat disc, which can be modelled in a simpler way, but this felt cleaner and more consistent.
However, I still feel like this a significant number of operations.
I need to make a few of these parts, and wanted to know if there was an easier and simpler way to model them?
(I'm tempted to write a featurescript to generate them, but would be happy to find a simpler way to do it)
Thanks.
