Tubing flat pattern
Is there a way to draw this piece in Onshape so that I can get a flat pattern? In Solid works I can draw it just like this and get a "flat pattern" which is the tube straightened out. I would need this straightened out version for the CNC tubing laser.
You need to have a split some-where. Would this https://cad.onshape.com/documents/d9c5c8cfb5c67ff48deb4f8a/w/cbd4e6f89e8f7b1544b3bc0f/e/2606ad6366f0099fbfcca1f1 work for you?
https://cad.onshape.com/documents/414cfeb061b17ebe62a44490/w/7fb34d697b3f6b914887e458/e/c5cfe7539f087efb66ebad56
@Lavon I'm sorry it was not, I just made it public so try again.
