How to make angle when extruding
MetrohzMetrohz Member Posts: 2 EDU
Im new to 3d designing and OnShape. I faced a problem. I want to extrude hole through my designed part but I need it to be at 10 degree angle. I saw some posts where people suggests using loft but its just not working out for me :/
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 233
    @justas_tarvydas There is a checkbox option in the extrude feature called "Draft." This will allow you to apply an angle to the extruded shape.
