Sketch distance cannot resolve
gauthier_östervall
Member Posts: 99 ✭✭
I am trying to use the distance tool to constraint a sketch.
Here is the blue line in my sketch, I am focusing on the top one. Manually movable:
Fixing the length with the distance tool:
When I try to change the length by entering a distance, the sketch becomes unresolved.
I don't understand why I can manually move the line to approximately where I want it, but not assign a length with the distance tool.
Here is the project.
What is going on?
EDIT: interestingly, it works if I remove the half circle. I don't understand why that half circle is blue to begin with, it's not movable after fixing the distance (in the picture with 8.91 above).
What is going on?
