Growth in Education Accounts Recentely,
mckeegan_curran
Member Posts: 6 EDU
in General
While I started messing around with OnShape earlier in the year due to not having a PC at home and thus not able to use AutoCAD away from school I found OnShape as an alternative that worked on my Chromebook. My along with many others has swapped over to this for the time being so I was wondering if there was a noticeable growth in new members around this time mainly with education accounts, if there's any reading this it'd be nice to see you chime in on thoughts and for the admin/staff I'm curious if you've seen this.
Like @mckeegan_curran said, you can use the free education plan form to "Sign up" for an account. Just make sure to sign up with the same email you are already using for your Onshape account. This way it will upgrade your account back to the education plan and it will be like nothing has changed.
You also should have gotten an email when your education plan expired. The email has a link that you can click to renew your education plan. Either way works!
