Remove tool with curved end
FunnyMan
Member Posts: 5 ✭
I am trying to remove something through the center of an object, and I want to make it so instead of the removing ending with a flat surface, it ends with a curve. I am fairly new to onshape so I am not quite sure on how to actually create the curve at the end of the removed part, without switching to a different plane.
https://cad.onshape.com/documents/ebe0cd116909e971d3212720/w/84cc1f2948a9b6821a424c4b/e/f2cf60ea451a2d7399996925
There are some perfect tutorial's for you to check -out
