Never ending story on loft twist
michał_piotrowski
Member Posts: 2 ✭
Hello
I'm struggling with lofting rounded rectangle to normal rectangle.
Is it even possible with single loft? Because it works as I want if I cut sketches to loft roundings separately.
Vertices matching does not help at all. Top rectangle has only 4 while bottom has 8 (and 4 more implicitly in centre of rounding)
Any suggestions? Especially if single loft is possible here.
@michał_piotrowski
It took a few tries, but I got it.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Website: ovyl.io
https://cad.onshape.com/documents/aded175ca0e019629e583205/w/70c3945785322f571366bb8e/e/5631c8fed6f2aad707a8b6bf
Website: ovyl.io
@bruce_williams
Thanks. That worked much better.
perfect - the UI is not intuitive. And for the OP your splitting the curve is necessary since the Connections do not play with End Conditions....yet.
