Curves on pipes
nicola_malagnininicola_malagnini Member Posts: 35 EDU
hi,
as you can see in the image, i must to connect hydraulic pipes with curves.. i tried to make a loft but, as you can see, the curve is squeezed. how i can do to make a curve with the same diameter?
thanks
