Is there a way to anchor parts in on shape?
chase_bender
Member Posts: 2 EDU
I am part of an FRC team participating in a FRC game design challenge. A template field is provided to the teams but none of the parts are mated together (more than 100 parts), the parts are already in the correct positions but can still be moved out of those positions. I know in inventor software there is an option to anchor parts in an assembly to one spot but I have not been able find such an option in onshape.
In the scenario you describe, where many parts are in their correct position but aren't mated, the "Group" mate feature can be very useful. Any parts in the Group will be fixed relative to each other: https://cad.onshape.com/help/Content/mategroup.htm
Hope this helps! (Sorry for the large image )
You will also want to "Fix" one of the components to set it in place relative to the origin. This will keep your overall field assembly from being moved when you click and drag.
