Make a feature pattern
davy_davy
Member Posts: 5 ✭
Hello,
I would like to make a barrier with the Linear Pattern-> feature Pattern.
I read this documentation here : https://cad.onshape.com/help/Content/linearpattern.htm?Highlight=feature pattern
But I can't seem to get it to part https://cad.onshape.com/documents/0d2ac74e64c3feda466b8e24/w/0ceb205c09205374b754fb97/e/e2c0166401740300f77b4af7
Could you explain me what's blocking ? Please .
Regards,
Davy
Regards,
Davy
I'm not sure exactly what you're going for here, but if it works for what you need it's always better (more stable and faster) to use the "part pattern" option. This situation seems perfect for that.
Website: ovyl.io
Thank you for your answer.
Website: ovyl.io
