Importing files
rod_muirhead943
Member Posts: 94 EDU
I successfully imported an ipt file into onshape. It is only an import file. There is not any feature history to work with. It appears that import files can not be modified as there are not any sketches and models features to manipulate or modify. Disappointing. Any modifications for this document in a folder in onshape would have to be modified in Inventor and then re-imported. Let me know if I am in error on this.
Thanks. Where are the direct editing tools and how does it work?
Here's a learning center course on Direct Editing: https://learn.onshape.com/courses/direct-editing
There are a number of tools in Part Studios like, Move Face, Replace Face, Delete Face, and Modify Fillet that are direct editing tools. They allow you to manipulate imported part geometry without the feature history.
