Solidworks user considering Onshape, some questions on its ability to handle large assemblies
scott_mayfield
Member Posts: 3 ✭
in General
Hi All,
I’m a physician by day, but I moonlight as a high end camper builder. Here is a link to the last project I finished and sold.
https://expeditionportal.com/expedition-portal-classifieds-award-winning-f550-full-custom-camper/
Ive been doing all of the design work in Solidworks, but I am running into some computing limitations. My models themselves are pretty simple, but I am working on a dell precision 7720 laptop that is limited to 16gb of ram. While my models are simple, they are mated to the cad models from Ford and Isuzu which are quite large and complex. I’m currently working on a ford transit build and the model is 200gb with an inordinate number of surfaces. I talked to puget sound about building me a new rig, but that would be in the 5-6k range on top of the Solidworks pricing. Because this isnt really a money maker for me, just cant totally justify that kind of expenditure, and to be honest, I’m tired of the constant updating and sharing models with other users with a different year of Solidworks.
Given my use model, how do you think Onshape will perform with these larger ford assemblies? I dont generally work with the vehicle model always open, I’ll mate the surfaces I need and then just switch over to the camper, but I do spend a fair amount of time with both open.
One thing that may work in your favor, is that you could import the large assembly, then when designing your parts, you could reference only what you need from the larger assembly. Check out the documentation around in-context design.
As you also mentioned, the ability to easily share things with others is really easy (if they're willing to sign up for a free account, or you're willing to create a link that anybody could open).
The largest learning curve coming from something like solidworks is probably data management in general, because there are so many different ways to link things together an organize your work, but there's some good information on the forums about what's worked for others.
I love your camper! I am more of a van camper person but that truck and camper makes me a little jealous.
In my experience all cad systems will bog down with large imported cad especially if it's complex and some are worse than others. Solidworks does this and so does Onshape. Your best bet is to create a public account and load up a representative file and play with it. Since it will be a public document give it an obscure name and then delete as soon as you are done to reduce the chance of others seeing it. If you know someone with Onshape professional account they could upload the file and then share it to you (I think).
Good Luck!
Christopher
