Sheet metal export
Hi
I've got a couple of questions about sheet metal exports I couldn't find answers to:
Is there a way to export all sheet metal flat patterns in a part studio, assembly or document? I have a document with a complex sheet metal structure which is slow and frustrating to export by finding the flat patterns and right clicking on individual parts to export when issuing a new version.
Also, is there a way to modify how files are named on export? As it is, the name of the part is OK, but a part number too would be even more helpful.
Many thanks!
Ian
Many thanks!
Ian
Re the export of multiple files simultaneously, we already do this for STL (from an assembly) and have an enhancement on the books for doing it for any file format. The workflow would be to drop each of the sheet metal parts (flattened) into an assembly one time, and then export as separate files in one go upon release. To have your Pro-Vote added to the list of requesters, please submit a feedback ticket.
As for naming the parts on export, you only need to rename the part to be the part number one time and they will be called that in all operations moving forward.
I hope this helps - Philip.
Thanks for the swift reply, I'll get a feedback ticket raised.
Not exactly what you are asking, but there is a batch option in sheet metal dxf export - notice the last check box here
What would be most useful, to many people I believe, would be a batch download of all flat pattern dxfs in the entire part studio using the Part Number as the filename (or at least part of the filename) within the zip.
