Sub Assemblys
bill_huggins
Member Posts: 2 ✭
in Drawings
I created a sub Assembly of (2) parts as a weldment.
I then inserted into a Assembly when I inserted into a BOM instead of one part i have the org parts.
How do i fix this?
How do i fix this?
Alternatively, you can combine the 2 parts in a part studio and combine them into a composite part. When added to the assembly, the composite part will show up as a single item.
Exclude all items in the sub assembly BOM and make sure you fill out properties for the sub assembly. Only the properties from the assembly level will be in the next level BOM.
Right click over items in the assembly BOM. The properties of each item can be set to not include in BOM from the part studio as well so they never show up in any BOM.
Part studio level properties.
Next level structured BOM shows only properties of the assembly and won't expand to individual parts.
