Add images to Assembly?
stephanie_bartolotta
Member Posts: 6 PRO
Is there any way to add images, such as, a decal to parts on an assembly?
I can insert the image into my part file, but once I insert the part into my assembly file the image gets removed.
Thanks for responding. Yes what you are describing is exactly what I would like to do. Below is a link to a document with an image of a smiley face that has been extruded. If you could please explain how to add the object plus the image to the assembly file I would greatly appreciate it!
Link to document
Your link is not public, and cannot be copied.
