Pipe with arc's
Kai_himself
Member Posts: 43 ✭✭
Hello,
i like to draw a pipe with two 45° Arc's. First i build up the straight pipes, then i rotate the arc's, at least i like to unite all.
Sometimes it works flawless and sometimes only the "arc" will remain as a sphere ...
Why is it so complicated to unite the parts ?
This is the link: https://cad.onshape.com/documents/7a8d26f803f84200fa808201/w/d98014a27a01bd55d731da93/e/34ea3beb6fa1fa3d3d793618
Best regards
Kai
https://cad.onshape.com/documents/b99fb219cc1e4fc997769150/w/36f89c0b58ab0790ef98dbdd/e/c856edf8b221b6b0af6d65d1
sounds like good advice. Your link is to Document page though.
The great thing about a program like Onshape is, it gives you numerous options
Here is another way — by no means the best – but rather, just another option
A desktop user can do this more efficiently
This way takes 2 features
In the sketch I use the —
Line tool
Dimension tool
Tangent arc tool
Tangent constraint
Then I use a custom featurescript called Pipe
The pipe tool is straightforward. Once you install it, you’ll see
Sorry for the jerky GIF. That’s the best I could do on a longer GIF on my iPhone
