I'm trying to use guides and can't figure out what I'm doing wrong....
caroline_read
Member Posts: 31 ✭
Optionsnav Member Posts: 258 ✭✭✭✭Hi @caroline_read checking out your image I see you selected the the sketch 4 as your guidelines, you have to select them individually by clicking in each guiding line, also I noticed that one of the guiding lines is inside the circle you have in the top parallel plane, so when trying to use it as a guide it creates an error due to the loft geometry you're trying to create I believe it intersect itself., not sure what the final intended geometry is but below some images of the loft. You may need more guidelines based on the final intended geometry.
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions7
@shashank_aarya
The loft feature isn't really working the way I want it to. I'm not sure why. I tried doing what @Narayan_K
did but I must have made a mistake some where. Any ideas?
