Movement of faces
stepan_soucek
Member Posts: 4 ✭
Hi,
I need move this faces (screws) a little bit more to the middle. Is it any possibilities how to do that? Something function like "direct edit" in Autodesk Inventor...?
Thanks for help.
Stepan.
Thanks for help.
Stepan.
Then as @NeilCooke says — use move face on the face of the holes (3 holes per bolt). Make sure the direction is normal to the top plane or the face of the cover
Then you’re gonna have to use transform to move the bolt
You’ll need to use one move face feature and one transform feature for the top three sets of holes & bolts
And then you’ll have to use a second move face feature and transform feature for the bottom three sets of holes & bolts.
In the below document, I applied the move face and transform to the upper right holes and bolt
https://cad.onshape.com/documents/17135219e755c41b7f9a6eda/w/e8339bee80c6e5abd3eed294/e/4c066007762c2d23c1f58edc
Thanks, I missed transform mode on move face function.
Btw. I know the removal boolean would help in this case, but i used it only for example.
