Extrude removing hole for set screw
pnutpro4pnutpro4 Member Posts: 6
Trying to create a pulley wheel with a set screw hole. Found a threaded hole in the public repository and am now trying to extrude the wheel and connect it with the threaded hole. When I extrude the wheel it intersects and fills in the threaded hole. How do I intersect the two and keep the threaded hole?
https://cad.onshape.com/documents/659fb1fc93be3c9bfb60f371/w/89491833fb27f86ba09ed205/e/15a163a0123d40804f4f6cbc?renderMode=0&uiState=61808c8e22e8c0568fe7e5a6
Thank you
