Design for 3D Printing
patrick_shea
Member Posts: 63 EDU
in General
I am trying to design a support for a 4" Plastic dust hose. Apparently my design will require a lot of support, that will need to be removed after printing. Looking for a bit of input an how I can make this easier to print. It is a 1 off piece, so if it takes time to clean up it is not a big deal. The design allows a couple of tie wraps to hold the hose on place.
Here is the part:
PLANER DUST HOSE SUPPORT | Part Studio 1 (onshape.com)
Patrick
Here is the part:
Patrick
I don't think the support is anything crazy in this case. It goes from 1:49 21g/$0.51 to 2:15 23g/$0.58 in Cura with typical settings for me. Probably not worth the time to optimize 7 cents off the print (assuming PLA), but you could try adding an angle with a sweep/replace face that matches the most extreme angle your printer can print. Alternatively, you could use a draft as an approximation. Here's the sweep/replace face example: https://cad.onshape.com/documents/1abe93154f1d0baa341b15c3
Here's what your model looks like sliced with Cura:
I believe his design has the wire-tie in that space, and the chamfer would cause it to slip off.
PLANER DUST HOSE SUPPORT - Copy | Part Studio 1 (onshape.com)
Also - I have Cura and a Prusa printer I and getting used to, but I was wondering if anyone is using KIRImoto? And where does that file go when I export it?
Pat
It's a bit difficult to put the Tie-wrap in the holes, so maybe 1 step further
https://cad.onshape.com/documents/582a266db2197f91d5ed5378/w/2d044cfd5f225a8c7289dfa4/e/5b8bb3bbceb99c5fe29161cf
