Surface fillets on vertices
christian_petty
Member Posts: 65 PRO
The fillet tool should be able to add rounds on a surface. Unless I am missing a feature, you have to split using a sketch fillet then delete the face.
Christian Petty - Mechanical Design Engineer, Radian R&D
Do you mean filleting a vertex vs. an edge?
I finally found the Creo feature I was trying to mimic: About the Vertex Round Feature (ptc.com)
Edit: https://cad.onshape.com/documents/ef138ff171d53d865231a306/w/af68f94c7a2f139edba35dc4/e/88b87524c0fd51b274fb1b2c
https://cad.onshape.com/documents/2f541e589f31e92e74aa8dcd/w/012577860bc17b670ad9ffd5/e/b408f034b3d40fbed77f596c
