assembly level cut feature?
chris_121
Member Posts: 3 ✭✭
Are there plans to bring in assembly level operations such as extruded cut?
When working with welded assemblies this is a very useful feature.
5
I suppose this is pretty standard feature and the least we should expect from Onshape is to meet the standard requirements.
I'm thinking a part studio would ideally be used (once the feature list issues are manageable) to model assemblies within which there was not relative motion. This would avoid the whole can of worms you get when assemblies and parts reference each other.
What's more, assembly operations (a single feature embracing many parts) get very difficult to manage in assemblies with relative motion...
I think we need to make sure we don't simply transfer our thinking from legacy packages across to Onshape, because we risk bringing a lot of our old problems with us if we do.
