Cant project curve from drum/tube intersection
aaron_skidmore
Member Posts: 34 ✭✭
in General
I have a tube and drum intersection. I will be laser cutting the tube, this cut need to be square to the tube. However I cant project the curved intersection between tube and drum onto a sketch. (I get check input error) Can anyone help?
below is link to model
https://cad.onshape.com/documents/8442c2dadb16758d46a2d09d/w/fa145863c24145e4fef629a1/e/e17c590e80579c2de2481671
is this what you were looking for ?
https://cad.onshape.com/documents/87101675e2b9a5ba0b253594/w/d40e500f0e833843d3946a12/e/80dab7f070b91d262cb81024
check the document now see if this is OK
this GIF will take you up to just before you do an extrude that is set to remove everything of an extruded Sketch 2, from what looks like a pipe to me
let me know if this answers your question
in this one, I don’t even bother to utilize the USE TOOL
USE TOOL
The third one uses a process of subtracted surface thickens to produce a normal to surface cut around a tube.
https://cad.onshape.com/documents/65753e08aca8d4b30d6b151b/w/7c9c24eefc69c7c393e4fae5/e/d091a7c9ce345849ff7d94cf
