Parts drawing not showing properly in assembly
vanya_evangelinevanya_evangeline Member Posts: 4
I just recently started using OnShape, and I just created a part with a threaded hole using the helix tool, but when I imported the part in the assembly, the helix isn't showing on the hole, so it's no longer threaded. I wonder what the issue is here and how can I fix it? Thanks in advance
Also, is there a way to flip a part on the Part Studio tab rather than the assembly tab?
