Scaling a pdf image import
geoff_josey
Member Posts: 65 ✭✭
I have imported a pdf image into a sketch where I will use the spline feature to trace various sections. The outlines produced will be used to laser cut formers.
I have spent some time reading the forum posts and managed to import the pdf image and position / align the image. I now need to establish the scale of the image to match the scale of the sketch. I have checked the drawing from the sketch and that prints OK 1:1 I have spent time adding dimensions without success. The vertical axes at 25 mm spacing need to align and the DWL line on the image align with the sketch vertical 0
https://cad.onshape.com/documents/64e339b875c6939713dde443/w/dc58ebb87288710c48326e70/e/058291458552a98f70eff256
Any help appreciated
https://cad.onshape.com/help/Content/sketch-image.htm?Highlight=Photo
