Creating Centerlines via opposite sides
Currently, to create a centerline you have to select the middle point on each end. I currently have a mitered tube and the profile view of this doesn't allow for accurate middle points. It would be much more ideal if there was an option to create a centerline by referencing parallel sides, and possibly more accurate than having to select points in more complicated drawings.
Definitely agree. We have this in the dev plan. Stay tuned and thanks for the great image in your post. it really helps convey your message,
