Direct editing of sketches
kevin_quigley
Member Posts: 306 ✭✭✭
Is there a way in Onshape to select a sketch early in the tree or a sketch that drives a feature, and directly edit the dimensions or points in the sketch WITHOUT having to go into the sketch and edit it (thus rolling back the tree and losing the visual feedback of the resulting feature)?
If not, there really should be.
This might not be an issue for some tasks but for many higher level modelling tasks it is very very useful to be able to directly edit sketch points or dimensions and see the geometry preview update in realtime. SolidWorks has this. Most lower cost modelling systems have this (SolidThinking, Rhino, SharkFX etc).
In the mean time, you can use the "Final" mode in the sketch edit dialog to keep the visual feedback.
