Workaround for hiding derived entity other than part
viruviru Member, Developers Posts: 619 ✭✭✭✭
edited August 2015 in General
Can anyone suggest workaround for hiding sketch and plane which is derived from other part studio. For better visibility of part studio there should be provision, after use of any derived entities they are not always required to show. Currently pressing 'P' also not work for hiding plane which is derived.
So, option to hide derived sketches, planes is helpful to adjust the better appearance of part studio.
Thank u!
With warm regards,
viru
    edited August 2015
    I agree, @viru, there are lots of important capabilities which Onshape need to add, and I'm sure will add, to derived elements. Including the ones you highlight here.
    I don't know of any workarounds: certainly it does not work to hide the sketches or planes in the Part Studio from which they are derived, and the "Derived" feature does not have any hide/show toggle.
    @andrew_troup , thank u!
