50 Digital Joints in Featurescript
Aaron_HooverAaron_Hoover Member Posts: 35 EDU
Hi Folks,
I'm embarking on a project to create FeatureScript versions of Jochen Gross' 50 Digital Joints (https://www.flickr.com/photos/satiredun/15868308421/sizes/o/). My goals are create a useful set of features for folks interested in CNC furniture manufacturing and to get more proficient in FeatureScript as I go. Caveat emptor: I'm a newbie to FeatureScript (but not to CAD programming and concepts), so bear with me if these features break spectacularly or behave in unexpected ways.
So far, I've implemented:
  1. A simple miter joint - https://cad.onshape.com/documents/9f4cce8606bea7e49e320254/w/b09b01b42cf427bd4a530258/e/32f3785f8f7f20d099d3a2ac (not one of the 50 digital joints, but it was a chance to get my feet wet with FeatureScript)
  2. The joint he calls "Halving with Elliptical Tenon" - https://cad.onshape.com/documents/adfedeff1e00a5990b0a77b7/w/aa9cf84b45740819a6fcca5e/e/c650a5eb2d645060e0907338
I have imported IGES models that I'm working from for all 50 joints, but since I can't share a folder by link, let me know if you're interested in seeing those. Also, let me know if you're interested in testing/improving my FeatureScripts. It's pretty tricky to create bulletproof features given the myriad ways a user can generate and manipulate geometry, but I'd like to understand how people might want to use these features.
Finally, if you have any suggestions for which joints you might like to see first, just let me know. Otherwise, I am starting with the joints that seem the easiest to implement first and working toward the more complex ones as I build my FeatureScript skills.
    edited October 2018
    Great stuff @Aaron_Hoover !
    Let us know if you need any help or have any questions :)
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,241
    One suggestion I have is to consider grouping some of the joints by mechanical function (e.g., corner joints or lengthening joints) into features that let you select the joint type.  That'll make it easier for users who don't have to manage 50 custom features and may want to switch between joint types.
  • Aaron_HooverAaron_Hoover Member Posts: 35 EDU
    This is a great suggestion. Let's consider an example, just so I'm certain I understand you. I might have a single frame corner joint feature, and then within that feature, there would be an option to select, say, "Halved Dovetail Corner Joint," "Halving with Elliptical Tenon," or "Jigsaw Miter." Then, the feature would conditionally expose parameters for creating the geometry based on what type of frame corner joint the user selected? This would be similar to the conditional logic for doing dovetails in the Box Joint feature, right?
    This would actually be very helpful to me as well from the standpoint of minimizing code duplication. On a related note, is there any way to reuse FeatureScript code across features (ie. a user-defined library)?
    Thanks for the feedback and suggestions!
    Hi Aaron,
    Yes, this is exactly what I meant.  You can certainly reuse code in FeatureScript -- a feature studio can define multiple features and utility functions that are not features.  Feature studios can also import other feature studios (from the same or other documents) to use their functions (as long as they are declared export).  The std is an example of a large code base with a lot of code reuse.
    Let us know if you need help with this stuff.
    Cool project!
    Couple things I think may be issues as you get to more complex joints:
    When you're generating the vector for the miter joint split plane, I think you're implicitly assuming it's drawn on the top plane, and not at some arbitrary orientation (Lines 56-57).  In my laser joint feature I ended up using cross product to find perpendicular vectors, and adding two unit vectors to find a vector pointing between them (e.g. into/out of a corner).
    More generally, it takes the vast majority of the time making sure it works at weird orientations and corner cases; I found it helpful to make several part studios in the document, each with a specific different corner case, to treat them like unit-tests for making sure it works.  Every bug report I get adds a corner case.
    Also, one thing I found: sketching with FeatureScript is really slow.  I found significant improvements by using the primitives where possible, transforming them, and then boolean subtracting/adding.  This might be less important for usability in your case if each feature only ever makes a single joint; I wanted mine to be able to drag-select everything in the part studio and work pretty well.
    Arul Suresh
    @lemon1324
    When you say primitives, do you mean like fCuboid and fCylinder?  Those use sketches as well to be created.  But yes, in general it will be probably be faster if you create your first tool with a sketch -> extrude, and then any matching ones with pattern.
    @Jake_Rosenfeld Yeah, the fcuboid.
    Interesting, are they optimized under the hood? Because I'm pretty sure I got to those by testing alternatives and finding that they regenerated faster than me defining my own sketch.
    Arul Suresh
    @lemon1324
    Thanks for the helpful suggestions. Yes, my features are pretty dumb at this point because I'm really learning FeatureScript as I go. I'm trying to create minimum viable product features that "work" assuming the user is doing something sensible (the idea of anticipating all the crazy ways a user could try to join to bodies, is a little daunting!).
    Also, thank you for the excellent Laser Joint feature, it's been my primary point of reference for learning FeatureScript (and I point all my first-year design students to it for any project that uses laser-cutting).
    PS - I see you're a PhD candidate in Mark Cutkosky's lab. I was a Stanford ME undergrad, and I did my PhD with Ron Fearing at Berkeley working on biomimetic multi-legged locomotion. Small world!
    @lemon1324
    They are pretty simple sketches, but they are not optimized under the hood.  You can see exactly what they are doing in the primitives.fs file of the standard library:
    https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/dc9e71d454d34142ae66df18
    Here is fCuboid:
    * Create a simple rectangular prism between two specified corners.
    * @param id : @autocomplete `id + "cuboid1"`
    * @param definition {{
    * @field corner1 {Vector} :
    * @eg `vector(0, 0, 0) * inch`
    * @field corner2 {Vector} :
    * @eg `vector(1, 1, 1) * inch`
    export const fCuboid = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
    is3dLengthVector(definition.corner1);
    is3dLengthVector(definition.corner2);
    for (var dim in [0, 1, 2])
    !tolerantEquals(definition.corner1[dim], definition.corner2[dim]);
    const sketchId = id + "sketch";
    var plane = XY_PLANE;
    plane.origin[2] = min(definition.corner1[2], definition.corner2[2]);
    const sketch = newSketchOnPlane(context, sketchId, { sketchPlane : plane });
    skRectangle(sketch, "rectangle",
    { "firstCorner" : vector(resize(definition.corner1, 2)),
    "secondCorner" : vector(resize(definition.corner2, 2))
    skSolve(sketch);
    const query = makeQuery(sketchId + "imprint", "IMPRINT", EntityType.FACE, {});
    opExtrude(context, id + "extrude",
    { "entities" : query,
    "startBound" : BoundingType.BLIND,
    "endBound" : BoundingType.BLIND,
    "startDepth" : 0 * meter,
    "direction" : [0, 0, 1],
    "endDepth" : abs(definition.corner2[2] - definition.corner1[2])
    const query = qCreatedBy(sketchId, EntityType.BODY);
    opDeleteBodies(context, id + "deleteSketch", { "entities" : query });
    So its a pretty simple operation, but not special compared to any other FS code.
