icons like in hole feature?
adamohern
Member, OS Professional Posts: 216 PRO
How are the icons added on the left of the hole feature length parameters? I don't see any mention of them in the std FS code.
That's not yet exposed to FeatureScript -- will come a bit later (probably with custom icons for your own features).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
+1 @adamohern. I need it to.
Hope we can use only the icon with no text either, only mouse tip whem hover.0 -
Actually you can use exactly the icons of the Hole feature if your annotations are named exactly as in the Hole FS of the std document
Like in this example:
<div>FeatureScript 961;</div><div>import(path : "onshape/std/geometry.fs", version : "961.0");</div><div><br></div><div>annotation { "Feature Type Name" : "My Feature" }</div><div>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)</div><div> precondition</div><div> {</div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.holeDiameter, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.cBoreDiameter, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.cBoreDepth, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.cSinkDiameter, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.cSinkAngle, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.tapDrillDiameter, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.holeDepth, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.tappedDepth, LENGTH_BOUNDS);</div><div><br></div><div> annotation { "Name" : "My Length" }</div><div> isLength(definition.tapClearance, LENGTH_BOUNDS); </div><div> }</div><div> {</div><div> // Define the function's action</div><div> });</div>Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2 -
@ilya_baran Are there other icons we can use?Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
I have just found 3 more
<span> annotation { "Name" : "My Length" } isLength(definition.dx, LENGTH_BOUNDS); annotation { "Name" : "My Length" } isLength(definition.dy, LENGTH_BOUNDS); annotation { "Name" : "My Length" } isLength(definition.dz, LENGTH_BOUNDS);</span><br>Un saludo,
Does offsetX offsetY and offsetZ work?0
NoUn saludo,
I think you guys got all of them... We plan on more customization in this area, but it's not the highest priority.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
