Struggling to recreate Configured Part Studio Reference Parameter
sam_parsons
Member Posts: 43 PRO
Hi,
I've been playing around with using instantiators in FS, but I'm struggling to recreate this example part studio:
https://cad.onshape.com/documents/c407dcc5516019b9d00703fd/w/3a0d436f95fd51d1428f7933/e/de203037b7ef2d6975acfd74
Where you would usually right click to 'configure with ...', I'm not presented with this option. But the example in the link above shows that someone has been able to do it. Though when I copy the example above, I can only remove the configurations, I can't set new ones.
Any ideas what's going on here?
Thanks in advance,
Sam
Thanks in advance,
Sam
1
kevin_o_toole_1
Onshape Employees, Developers, HDM Posts: 565
Hi Sam,
You correctly identified a bug, and this issue was fixed in the latest release of Onshape (1.117) last Friday. The right-click menus for these parameters should now always be appearing correctly.
In the future, you can use the "Report a bug" or "Contact support" option in the "?" menu for a faster response time, and an email notification when the issue is fixed.
Let me know if there's any further issues!
– Kevin5
– Kevin
