Improvements to Onshape - July 13th, 2021
CAD IMPROVEMENTS
IMPORT IMPROVEMENTS
Split into multiple documents is improved to take advantage of our unique document structure.
IMPROVED ARRAY AND MAP ITERATION FOR FEATURESCRIPT
Now, define your for loops with the key and value within the declaration:
for (var index, value in myArray)
}A similar syntax is allowed for maps as well:
for (var key, value in myMap)
}These improvements are equivalent syntax to the existing map/array iteration in Featurescript. See the Featurescript Documentation for more details.DRAWING IMPROVEMENTS
TABLE SUPPORT FOR ALT + ENTER
Create new lines within a table by holding ALT(Option) while pressing Enter.
GROUP NOTES WITH DRAWING VIEWS
You can group notes and drawing views by pre-selecting them and choosing Group from the right-click in context menu.
PROFESSIONAL IMPROVEMENTS
RELEASE MANAGEMENT CHANGE DETECTION
RELEASE MANAGEMENT WARNING IMPROVEMENTS
Release Management now detects and warns the user if the candidate contains an obsolete component.
ENTERPRISE IMPROVEMENTS
ANALYTICS IMPROVEMENTS
MOBILE IMPROVEMENTS
SELECTION IMPROVEMENTS IN IOS
LINK SHARING IN IOS
Activate Share links directly from your iOS device.
For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Onshape Documents and over the next few days these features will also be available in Documents created before the date of this update.
glad to see improvements in import. Organizing is a big time saver.www.accuratepattern.com2
Change detection to prevent making unnecessary revisions will be a lifesaver. I've had to make so many individual obsoletions to correct that mistake.Ben Taylor
Lead Mechanical Engineer @ Healing Innovations3 -
Big improvements to importing and change detection. Thanks Onshape team. New superpowers every three weeks
1 -
The import improvement is great! ps, does this make the import tree come in in order, instead of upside down?
These little FS tweaks are always welcommed, thanks!
1 -
Love the FS 'for (var index, value...)'.....thanks!
Design Engineer | Anerdgy AG1 -
Glad to see improvements being made on the drawings.0
the imports improvement will be very handy especially if you have A lot of legacy files you need to upload from old software0
Very helpful
RELEASE MANAGEMENT CHANGE DETECTIONRELEASE MANAGEMENT WARNING IMPROVEMENTS
(Would love to prevent a release candidate due to an obsolete PN)0 -
Really like teh import organizing that is done.1
The new import feature is awesome. I had an assembly I had to upload that has a cluster of subassemblies in it and it parceled the subs out with their parts in each document. It is so easy to find the items I need to work with in this structure. I'm doing my happy dance!2
Love the RM improvementsAdrian V. | Onshape Ambassador
CAD Engineering Manager1 -
I see you have also added opHole() function into the standard library. Found it when faced name conflict with my own opHole function
3 -
Thanx, great improvements0
