Edit Line Thickness in drawing
ehsan_pazooki
ehsan_pazooki Member Posts: 52 ✭
edited January 2022 in Community Support
Hello Guys,
is it possible to change the thickness of the lines in drawing?
regards
Essi
  • ehsan_pazooki
    Hi fnxf,
    It's there. Thank you very much.
  • john_kraljic
    john_kraljic Member Posts: 2 EDU
    As a follow up to the line thickness question, is it possible to change the line weight to a value that is not listed?  I would like to be able to change to 0.05 mm for cutting on a laser/engraver.
    Thanks,
    -John
  • HansPeterHaastrup
    HansPeterHaastrup Member Posts: 5 EDU
    +1 for line thickness adjustment.
    If implemented we can skip a step through Inkscape and directly send the drawing to the laser cutter
  • Andrew_Gillies
    Andrew_Gillies Member Posts: 2 ✭✭
    +1 for this as well - same reason. Need to set to 0.05mm for laser printing
  • brendan_o_halloran
    brendan_o_halloran Member Posts: 2 EDU
    Any update on this, changing line thickness to 0.05mm?
