Sheet Metal: edit flat pattern
xiss_burg
xiss_burg Member Posts: 7 ✭
I have created a sheet metal part from an existing model using Thicken with Tangent Propagation. Now I'd like to edit the flat pattern (specifically I want to increase one of the chamfers, see linked document). A sheet metal part created from scratch would have a sketch that could be edited to achieve this. What about this case? There's no sketch.
Thank you!
  • martin_kopplow
    martin_kopplow Member Posts: 1,612 PRO
    You could make a sketch on the flat pattern or use the direct editing tools. .
