Is there a way to make holes in a non linear face
malo_cornil
malo_cornil Member Posts: 2 ✭
Hey, I'm modeling a lamp with a kind of spherical lampshade, is there a way to drill holes in it once its created and if not is there a way to bend a cylinder with the holes already on to shape it right ?
here is my model so far if you want to have a look at it.
Thanks guys :)
  • Kevin_Cowles
    Kevin_Cowles Member, Onshape Employees Posts: 90 image
    Image didn't load properly, could you possibly share a Link Share to the model? Or post another image? Thanks!
    You can certainly use Conical sheet metal to create that type of geometry, modeling the holes in the flat pattern.
