Help with joining two pipes into one
jon_jones266jon_jones266 Member Posts: 2
I'm trying to join two pipe inlets into a single outlet, which I've done (I think) as a solid using Sweep. They have joined, I have used a Boolean Union to join all the parts into one and I feel all appears okay.
I now plan to Shell out the whole pipe arrangement, however this is where I am stuck. When I attempt to Shell I get an error at two points where the inlet pipes amalgamate into the single outlet.
Can I get some help on the best way to achieve my outcome please? I ultimately want the pipe union, but also to learn the best way of doing it.
Thanks in advance.
  • shawncrockershawncrocker Member Posts: 20 ✭✭
    You might have a radius or something that becomes too small while the shell features tries to offset the surfaces to make the shell. It hard to guess without any images or anything though.
Howdy, Stranger!
