What is the best way to put a pattern on a flat surface?
cory_isaacson
cory_isaacson Member, Developers Posts: 43 PRO
i have a flat glass part and need to show a frosted area on the flat surface. I would like it to be a different color than the glass and also control the transparency. Should I make 2 parts and assemble them? Adding a sketch for the area seems not to work well (I am even having trouble positioning it correctly even though there are no constraints that should stop it).
