How to reference computed dimentions?
w_s856
w_s856 Member Posts: 63 ✭✭
Context: https://cad.onshape.com/documents/43358821734fb73d04655e55/w/8ca61270631d958a341420cb/e/8a4842f7c0f2c7a0c7ed0ee8?renderMode=0&uiState=665487845d581a3dee7d001e
I am building my first Onshape object and so far the experience is great (I am coming from FreeCAD). I have a basic question about references: can I reference a dimension that computed by Oneshape? Specifically, I would like the separator in my box to be in the middle.
This means that I must set the constraint to a/2-b/2. Can I reference a and b? Or do I have to adjust as the dimensions change?
I am aware that I could set two constraints on the edges of the separator so that both are equal (constraints from the edge to the vertical edge of the box) - I do not know yet how to use construction lines but I will find this. I would like nevertheless to understand if references such as the nad b above exist in Oneshape
