Any way to rename Frame parts by their length?
joshtargo
Member Posts: 610 EDU
I want to see the lengths of each frame piece in the final Master Assembly BOM, is there any way to get length data in the BOM?
The cutlist properties for each frame part can be read, and have the name set by the feature.
If you just want the length property in the BOM, you could use a computed property.
I wrote up a quick sample you can see here of using a feature to set the name.
My document is set to public, you should be able to view it.
The computed properties page is a bit out of date. Its definitely supported in professional accounts.
