Having trouble with wrap
mark_picard
Member Posts: 2 ✭
Hello everyone. I am new to onshape and have looked through some tutorials. Every once in a while when I am sketching I pause, wrap, and make sure everything works. This time it said, " wrap did not regenerate properly failed to thicken all selection" I am not sure if I have some weird geometry so I would appreciate some help. Thank you. I am trying to wrap sketch 5 on shape 1 and make it solid not surface. surface works but not solid. https://cad.onshape.com/documents/d35ee3447816df9c711bd9ff/w/931a0993359ffd3009efa758/e/3508f8f47c7556eb46687210?renderMode=0&uiState=669c1c4c3146c131d6bb8e7c
seems like you fixed it yourself. probably some sketch not closed.
you could also try this tool. maybe its better suited for your work: https://cad.onshape.com/documents/0bb13c1b6ed6d4a6dd75cf99/w/b4493d47a45c27ce485c84b9/e/d12c4d024908a2d4e902fcfanice work tho. you could also try to use gimp/Photoshop/whatever to auto mask the designs and create svg files to import.0
